Inviato 06 April 2014 - 13:50
Hi there
My tachometer stopped working while riding today. I am 100% shure that tacho is ok because i have two of them and and i tried to switch them and both of them don't work. What else could be wrong? from where tachometer get signal to work? probbably from alternator . check alternator connector and i have current while engine is running just on black and red wire that is duble on singgle black and red wire there is no current. If i check tacho connector i have current on two wires ??
Any advice what to do?
Inviato 06 April 2014 - 15:37
Check the wires are joined to tachometer
Inviato 06 April 2014 - 20:21
all wires are ok
Inviato 07 April 2014 - 16:51
Mito II tachometer is meccanic, controls the steel wire which is located to the right of the engine block
Messaggio modificato da a7n8x il 07 April 2014 - 16:55
Inviato 07 April 2014 - 18:30
No i have 1995 mito witch have electronic tacho
Inviato 07 April 2014 - 19:01
Fix your profile card
ludiluka, il 06 April 2014 - 13:50, ha scritto:
Hi there
Yes! the signal is taken from a red / black wire alternator
Inviato 13 April 2014 - 11:15
and how can i measure if i have signal on red/black wire?
Inviato 13 April 2014 - 14:50
multimeter
but instead of measuring the signal from the wires red / black, I would check that the wires are connected properly, because the wires red / black are also used to operate the unit (if it was a problem with the bike alternator should not work).
Inviato 16 April 2014 - 23:14
Everything is conected ok because everything was working fine until tacho decided to stop worikng
