Sensore Di Temperatura Del Motore
#1 diegoesprt
  • 1 Messaggi:
Inviato 17 June 2016 - 21:06
acquistare la sp 525 con pennarello Koso, hanno annullato il sensore di temperatura del motore.
e ho notato un eccessivo consumo di olio, ECS avrà bisogno delle informazioni del sensore? :teach:
  • 6896 Messaggi:
Inviato 18 June 2016 - 00:31
Puoi rispiegare meglio? Non ho ben chiaro cosa intendi per pennarello koso e per il sensore temperatura annullato.
#3 snowknifa
  • 290 Messaggi:
  • Provincia: Siracusa (SR)
Inviato 23 June 2016 - 09:16
penso abbia tradotto dall'inglese con qualche traduttore, forse conviene provare a parlargli in inglese
koso has his own independent water temperature sensor so the original one has been removed but you do not have to worry about it. It has no influence on ecs behaviour. If you noticed there is an excessive oil consumpition you should look for the top of the carburettor...there should be a connector on the top...if this is disconnected you have oil consumption problems.That sensor controls the quantity of oil provided from the electronic oil pump, so if disconnected it start sending so much oil to prevent damages. Actually if that was the case you should notice some warnings from the mil led in the dashboard. LEt us know better what is the problem and we will help you.
ps. also the fact that the original water sensor has been removed could cause some mil blinkings
spero di essere stato d'aiuto
Messaggio modificato da snowknifa il 23 June 2016 - 09:26
