Hi,
i have 90087 cylinder, are the 1,5mm right, that i have to lower engineblock?
Thats my only question.
I have to send the engine and the crank (for rebuilding) to my engineservice, and he have to milling my engineblock for 90087 and usual pistons.
Thank you!
How much more radial clearance have lower Conrodneedlebearing?
1
Block Lowering For 90087
Iniziato da Phil_W, Feb 11 2009 22:35
Inviato 11 February 2009 - 22:35
Inviato 12 February 2009 - 00:12
Phil_W, il Feb 11 2009, 10:35 PM, ha scritto:
Hi,
Thank you!
Thank you!
what is con rod needle bearing???
Inviato 12 February 2009 - 15:34
è la gabbietta a rulli della di biella però non ho capito se testa o piede...
Inviato 12 February 2009 - 15:49
piede 8albero non pistone)
Inviato 26 February 2009 - 23:14
La testa di biella non è al pistone ma all'albero, bottom end in inglese.
la biella si legge capovolta.
