73037 Cilindro Nikasil Crack.
Inviato 18 November 2009 - 10:53
this is friend's mito cylinder output view.
full overhauling 2month ago. piston,crank,cylinder,bearing.
oil use motul synth 100%. fullness preheating before riding.
but problem came by the middle of domesticate.
milage just 2000km. (almost brand new condition. you can see the clean exhaust port!)
73037 nikasil coat cracked.
can see the port's coat crack & bubble scar.
now i use 66650E. I had same problem at used 73037 too.
similar crack at that time.
this scars hard to stick oil layer.
and it will be sculpture depth at piston.
i think that's not user fault. maybe 73037 has defects. how do you think?
Inviato 18 November 2009 - 13:08
Messaggio modificato da marco 2t il 18 November 2009 - 13:14
il mio angolo di cielo ...
Inviato 18 November 2009 - 22:41
Inviato 21 November 2009 - 17:27
no carbueration change. all units are normal. just mito EV 2000year model stock condition.
Messaggio modificato da madbunny il 21 November 2009 - 17:29
Inviato 21 November 2009 - 17:33
Inviato 21 November 2009 - 18:33
Nitrus, il Nov 21 2009, 05:33 PM, ha scritto:
Messaggio modificato da {mRk} il 21 November 2009 - 18:30
Inviato 21 November 2009 - 18:37
Inviato 22 November 2009 - 05:26
cagiva originale pistone 55.98mm dimensione.
I don't have Bore vernier caliper.
so i don't know how cylinder diameter is.
Inviato 22 November 2009 - 12:06
that's probably the problem.
you have to know the diameter before you buy the piston.
probably your piston was not suitable for your cylinder
Inviato 24 November 2009 - 21:28
non si vede dalla foto se la spaccatura sia giunta anche sul cilindro vero e proprio, se cosi fosse, il cilindro non è più recuperabile vero?
