Aftermarket Fuel Tank? Fiberglass Or Carbon
#1 Jeram
  • 54 Messaggi:
  • Moto: Mito SP525 Pista
Inviato 11 February 2012 - 03:51
Hi,
Excuse my lack of itailian.
Does anyone know of any fiberglass or carbon mito fuel tanks or just the outer tank shells to use as a cover?
I require one for my race bike that is of the EVO shape.
or does somone know anyone with a mold?
in italiano (google)
Qualcuno sa dieventualifibre di vetroodi carbonioserbatoi di carburanteMitoo soloi gusciserbatoio esternoda utilizzarecome copertura?
Hobisogno di unoper la miabici da corsache èla formaEVO.
Conoscete qualcunocon uno stampo?
#2 PrizeGold
    Lucky Explorer
  • 2853 Messaggi:
  • Provincia: Foggia (FG)
Inviato 11 February 2012 - 14:44
Sorry, but i don't know about existing carbon fiber fuel tanks, unfortunately you should try asking some specialist that can build it with your specifications.
#3 AndreaNSR125
Inviato 12 February 2012 - 02:07
Maybe you can search something fOr the ducati 998 Or similar, but I think they are wider.
You can ask someone to build one, but it will be really expensive (I work carbon fibre and I can assure this) something as some hundreds euro for a good product...
If you need only a cover, there is the possibility to put a carbon fibre skin over the original tank,which would cost under 100 €
#4 Jeram
  • 54 Messaggi:
Inviato 12 February 2012 - 13:49
will be a few hundred to get the mold made and a simple cover done, then will make a super thin aluminium tank that sits inside.
I dont like the idea of a full carbon tank that holds fuel as it may rupture in a crash and cause the bike to burn.
Iv already to got the carbon Iv got a 5meter roll,
carbon is very cheap when it is non-structural, it is the labour needed to make the mold and lay the mold that is expensive.
#5 AndreaNSR125
Inviato 12 February 2012 - 23:21
I'm sorry, I didn't understand completely what you are saying...
a good carbon fibre tank doesn't crash...
and btw, carbon fibre isn't cheap at all... and i'm talking about industrial prices.
Anyway I think you wanted to say that the material cost is far lower than the labour needed in production, and I completely agree.
