Hello i want to know if "raccordare guida flussi" using tm 35 is a good job?
I've been looking manifold and guidaflussi and it's too small (around 28mm) compared to mikuni 35 mm bore.
I planned to rebore the guidaflussi and manifold to 35mm
Sorry if this info are on other post, but i don't understand very well italian and sometimes it's difficult to interpretate.
Thank you!
Raccordare Guida Flussi
Iniziato da cervatillo1985, Feb 15 2012 23:01
Inviato 15 February 2012 - 23:01
Inviato 18 February 2012 - 14:00
Hello again, nobody know this question?
Thank you!
Thank you!
Inviato 20 February 2012 - 21:33
i translate for you
Ciao volevo sapere se raccordare il collettore e il guidaflussi usando un mikuni 35mm è un buon lavoro,
ho osservato il collettore e il guidaflussi e mi risulta molto piccolo (circa 28mm), rispetto al diametro 35mm del carburatore.
Pensavo di allargare il guidaflussi e il collettore a 35mm.
Scusate se queste informazioni si trovano in qualche altra discussione ma non capisco bene l'italiano e a volte mi è difficile comprenderlo.
Grazie
Grazie
Inviato 20 February 2012 - 22:00
Ciao
the splitter hole has got an oval shape, turn this little opening (little because the splitter is the same as for the dellorto 28mm version as for the mikuni 35mm)
to a bigger oval (that has got the total area of a circle of 35mm diameter)
then
if the manifold has got a intake duct with an area amenable to a circle of 35mm, ok, do nothing, if is tight you can proceed to rebore with care from the 35mm of the carburettore to the new oval shape of the splitter
but
if you have got the specific cagiva 35mm manifold ...i think the manifold must be ok
then
but
Inviato 21 February 2012 - 23:03
Thank you!
