Messaggio modificato da Tallus il 01 March 2012 - 16:48
Problem With Cagiva Raptor 09
Inviato 01 March 2012 - 15:53
Inviato 01 March 2012 - 17:36
Tallus, il 01 March 2012 - 15:53, ha scritto:
Replace the pipe with a much better, for example the SP replica:
contact Mat in this topic
Inviato 01 March 2012 - 20:13
Inviato 02 March 2012 - 12:00
Tallus, il 01 March 2012 - 20:13, ha scritto:
The original exhaust is worth
The dyno measures the power engine, but it is said that it is true also with regard to the speed reached
As regards the secondary air, the closed or have simply disconnected? greatly affects.
Inviato 02 March 2012 - 14:53
Messaggio modificato da Tallus il 02 March 2012 - 15:54
Inviato 02 March 2012 - 23:23
The secondary air does not have to use. The important thing is that you close the pipe going in the expansion
No
let it be, that's not the problem
Messaggio modificato da a7n8x il 02 March 2012 - 23:25
Inviato 15 March 2012 - 21:28
Messaggio modificato da Tallus il 15 March 2012 - 21:28
