Correct Mix 2t Oilxgas
#1 pnoce
  • 5 Messaggi:
  • Moto: SuperMotard
Inviato 13 December 2006 - 21:36
Hi there, my oil pump is not working well and I am intending to mix motul 600 direct to the gas. Wich is the best rate ? 2%, 3% or 4% ?
Regards
Paulo from Brasil...
#2 aleale
  • 9167 Messaggi:
Inviato 13 December 2006 - 21:39
mito pump works at 2%
#3 nrgs4
  • 8746 Messaggi:
Inviato 13 December 2006 - 21:54
magar! it lavor a 1\1,5, not di più, purquà yu fait wit un pien di oil over 1000km!
#4 marco1988
  • 6841 Messaggi:
Inviato 13 December 2006 - 22:24
ma dai smettetela di prendere in giro!!
arriva uno straniero, diamo almeno impressione di un briciolo di professionalità, già ci vuole un bel coraggio a scrivere in un forum italiano, facciamolo almeno sentire a suo agio!!
anyways..
hi there :lol:
oil pump not working correctly is common problem of cagiva mito engines!
i'd recommend you to replace the pump with a new one!
the pump does not have a fixed oil ratio, it depends by the engine's rpm and by how much you open the throttle..
the percentage is variable, from about 1% to 2% and over.
in my opinion keeping the automatic pump is the best choice, because it sends some oil in the cylinder also when you brake and totally close the throttle (because the ratio depends also by the rpm)
if you manually mix the oil, instead, there is no lubrication at all, when you close down the throttle, leading to a major risk of damaging your engine when you brake.
anyways, if you decide to get off the pump, i'd recommend you a percentage not less than 2%, 2.5% if you spend most of the time using all the potential of your bike!
bye!
#5 pnoce
  • 5 Messaggi:
  • Moto: SuperMotard
Inviato 15 December 2006 - 01:24
thank you all !!! and sorry for the english, but at least I have italian blood in my vanes ! my surname is NOCE !!
paulo
