che carburatore metto sulla mito2???
Inviato 17 October 2004 - 19:13
Inviato 17 October 2004 - 19:21
Inviato 17 October 2004 - 19:41
Inviato 17 October 2004 - 21:07
Inviato 18 October 2004 - 09:33
Inviato 18 October 2004 - 09:49
28 rd is on it, like racing model from cagiva and a bigger carb isn't always good solution!!!
if you want to put a bigger carb, you need the 2 parts before and after pipe (connection carb to cylinder diameter 35+coonection to airbox that is longer than original one) extract from ev model 7 speed !!!
After that, you can put 34 dellorto or 35 mikuni !!!
35 mikuni is better to set because the carb is used on mito ev !!!!
However, I need your cylinder number cagiva to say if your cylinder can receive a bigger carb !!
Inviato 18 October 2004 - 12:02
http://img84.exs.cx/img84/7699/thissssssssss.jpg
NEL DUBBIO NON MOLLARE... TIENI LUNGO!!!!
Inviato 18 October 2004 - 12:23
Inviato 18 October 2004 - 14:01
Inviato 18 October 2004 - 21:33
prestazioni elevate e anche consumi xo se vuoi il max devi montare questo
il motore + gira + ha bisognio di miscela
suggerirei anche un ritocco dell'anticipo
se vuoi stare sul tranquillo 38 mikuni :cappello:
lo consideriamo un salto di qualità????
NESSUN UOMO VIVE A LUNGO QUANDO MUOIONO I SUI SOGNI
ANCHE I MIGLIORI SBAGLIANO,MA SONO CAPACI DI RIMEDIARE...PER QUESTO SONO I MIGLIORI...
wlf 4ever...e w la mito!!!e il cmc!!!
16-10-05 prima pistata della mia vita
Inviato 18 October 2004 - 23:22
mito 1,mito 2, mito racing=28rd
mito ev 7 speed=35 mikuni
mito ev 6 speed=28bd
35 mikuni is in fact the same as 34 dellorto in size....
Inviato 18 October 2004 - 23:40
Inviato 21 October 2004 - 12:12
Inviato 21 October 2004 - 12:13
Inviato 21 October 2004 - 13:24
Inviato 21 October 2004 - 14:13
Inviato 22 October 2004 - 12:07
Inviato 22 October 2004 - 12:41
