Thank you for the compliments
Engine was totally standard & good condition apart from the dirt. The bottom end had been replaced already, but balancer timing was wrong...lots of vibes...that's why it was sold in the first place.. .. I replaced the piston & rings though.
The only other parts that were bought / changed / new...
Wheels to 6 spokes with new tyres
Renthal bars & new grips
Chain & sprockets
Brake pads
Exhaust
Front fairing
Paint / decals.
The Mito speedo was not a direct fit. I changed the cable drive head for the planet one & made some adapters to make it all fit correctly. Not easy so I am using the Planet one on the other bike this time.
Temp gauge uses a standard mito sender & I added wiring to connect it up
Tacho was wired into the RH switch gear to get it working, +12, Kill switch & 0v
