Blackbox restricting???
Inviato 21 August 2005 - 13:44
I have this friend who got a Cagiva Mito 1999 model. He has a Shark exhaust and a Dellorto 34mm carburator standing on it now..... He rides with the correct sprokets of 14/41 and can only make 120 km/h (65mph) tacko!!!!!!!
He`s wondering if it is a blackbox restricting on he`s bike, but he don`t know for sure.....
So does anyone on this forum know if it could be any blacbox on he`s bike?
Anyone that knows how to derestrict a blackbox (witc wires to cut ect...)
Thx for any replyes
Jolly stradale 0206, ported 73037 cilindro, 200H head, flat 1 ring piston, 35mm mikuni carb, modified airbox.
Soon planned:
Crc for 9 serie, sp cilindro 9008, sp testa 200? + mahle piston, keihin pwk 38mm, sp lamelle carboni, kokusan denki ignition, sp525 farings, painted rims in gloss black++
Inviato 21 August 2005 - 13:53
Thx for any replyes
it is this!you are remove for good sound and good performance!
Inviato 21 August 2005 - 13:58
blackbox is a box that cut the power at 8000-9000 rpm`s and it don`t let you go over 120 km/h taco.....
and a other thing, I have removed this cap from the airfilter for better sound and better performance on my bike (as shown), but doe`s this do anything to my bike?????
Soon planned:
Inviato 21 August 2005 - 14:15
it is not what it cuts giri!never the myth in Italy to the telephone exchange that limits the giri.forse from you in Norway is different!i knows that only the aprilia rs125 it has this sistem.basta to open the telephone exchange and only to cut a thread that ago gives bridge!
Inviato 21 August 2005 - 14:18
forse=maybe
basta= u must only....
Ma cosa c'entra il ponte?
VENDO ARTICOLI DA SOFT AIR A PREZZI STRACCIATI-VEDERE MERCATINO
Inviato 21 August 2005 - 14:22
Inviato 21 August 2005 - 14:23
Inviato 21 August 2005 - 14:32
Inviato 21 August 2005 - 15:05
Solo che non ho capito se è la centralina d'accensione o chissà cosa perchè ho visto più volte che su qualche sito vendevano la "black box" senza limitazioni e allora a questo punto penso che sia la centralina di accensione.
E' una cosa strana....
Inviato 21 August 2005 - 15:15
Inviato 21 August 2005 - 15:18
Inviato 21 August 2005 - 15:27
AlexMitoEV, il Aug 21 2005, 03:18 PM, ha scritto:
ragazzi ma l'inglese lo avete imparato al CEPU???
"have you removed the appendix on the exhaust?"
Inviato 21 August 2005 - 15:39
1)Lo scopo non sia quello di imparare l'inglese "correggiuto" ma di aiutare na persona che ha chiesto na mano;
2)L'importante è che si capisca il senso della frase;
3)Il verbo "to have" può anche essere usato col "do" nelle interrogative in alcuni casi. Questo è uno di quelli.
4)Si vede che non hai mai sentito gli americani parlà...
Inviato 21 August 2005 - 15:50
Did you have done the right set up on your carburator? How does the spark appear? Black, white or brown? Make this...Do some photo to the engine, the airbox and the exhaust so we can see better that there is something wrong on your baby!
Quanti errori ho fatto?
Inviato 21 August 2005 - 17:44
Benza Power 4EVER!!!
