Blackbox restricting???
21 risposte a questa discussione
#1 mitonorway
  • 38 Messaggi:
Inviato 21 August 2005 - 13:44
Hi,
I have this friend who got a Cagiva Mito 1999 model. He has a Shark exhaust and a Dellorto 34mm carburator standing on it now..... He rides with the correct sprokets of 14/41 and can only make 120 km/h (65mph) tacko!!!!!!!
He`s wondering if it is a blackbox restricting on he`s bike, but he don`t know for sure.....
So does anyone on this forum know if it could be any blacbox on he`s bike?
Anyone that knows how to derestrict a blackbox (witc wires to cut ect...)
Thx for any replyes :Baldoria 2:
Mito evo 2 with:
Jolly stradale 0206, ported 73037 cilindro, 200H head, flat 1 ring piston, 35mm mikuni carb, modified airbox.
Soon planned:
Crc for 9 serie, sp cilindro 9008, sp testa 200? + mahle piston, keihin pwk 38mm, sp lamelle carboni, kokusan denki ignition, sp525 farings, painted rims in gloss black++
#2 aleale
  • 9167 Messaggi:
Inviato 21 August 2005 - 13:53
what do you mean with blackbox?
#3 bizio88
  • 2478 Messaggi:
  • Interests:Moto e ovviamente ragazze
mitonorway, il Aug 21 2005, 02:44 PM, ha scritto:
Hi,
<{POST_SNAPBACK}>
it is this!you are remove for good sound and good performance!
#4 mitonorway
  • 38 Messaggi:
Inviato 21 August 2005 - 13:58
now, not exactly this.
blackbox is a box that cut the power at 8000-9000 rpm`s and it don`t let you go over 120 km/h taco.....
and a other thing, I have removed this cap from the airfilter for better sound and better performance on my bike (as shown), but doe`s this do anything to my bike?????
Mito evo 2 with:
Soon planned:
#5 bizio88
  • 2478 Messaggi:
Inviato 21 August 2005 - 14:15
<{POST_SNAPBACK}>
it is not what it cuts giri!never the myth in Italy to the telephone exchange that limits the giri.forse from you in Norway is different!i knows that only the aprilia rs125 it has this sistem.basta to open the telephone exchange and only to cut a thread that ago gives bridge!
#6 ALex
    you are gay!
  • 6200 Messaggi:
  • Interests:Motociclismo<br />Hockey in-line e ghiaccio<br />Calcio<br />WLF
  • Provincia: Varese (VA)
Inviato 21 August 2005 - 14:18
giri=rpm
forse=maybe
basta= u must only....
Ma cosa c'entra il ponte?
VENDO ARTICOLI DA SOFT AIR A PREZZI STRACCIATI-VEDERE MERCATINO
#7 bizio88
  • 2478 Messaggi:
Inviato 21 August 2005 - 14:21
ho usato un programma di traduzione e mi sembra di aver capito ke la mito del suo amico nn supera i 120 xke a un blocco sulla centralina tipo rs!forse in norvegia la legge è diversa e hanno questo sistema!boh! :Baldoria 2:
#8 ALex
    you are gay!
  • 6200 Messaggi:
Inviato 21 August 2005 - 14:22
Ma no non credo... Dici?!
#9 aleale
  • 9167 Messaggi:
Inviato 21 August 2005 - 14:23
no x me dice ke nn trova l'aèèendice della marma da levare oppure il blkko d plastica dell'airbox!
#10 bizio88
  • 2478 Messaggi:
Inviato 21 August 2005 - 14:26
no la marmitta nn centra perke ha la shark(anke se nn so se è omologata?)diceva blokko dei giri nell'altro messaggio!e poi per fare 120 o è un bidone ho ha qualcosa perke anke con la marma omologata va di più!
#11 ferrocomix
  • 969 Messaggi:
  • Provincia: Bergamo (BG)
Inviato 21 August 2005 - 14:32
io penso che abbia tolto il collettore del filtro e infatti dice che il rumore e' migliorato pero' non va quindi bisognerebbe capire se e' depotenziata e come.... puo' essere che oltre ad essere depo abbia anche una modifica alla centralina da qui il fatto che e' un bidone.... :Baldoria 2:
#12 Duken
  • 948 Messaggi:
Inviato 21 August 2005 - 14:37
Dovremmo spiegargli del ripotenziamento base. Se quello non basta ha la centralina bloccata, in qualche modo...
AGV Ti-Tech Tattoo Red
#13 InTh3Dark
  • 1098 Messaggi:
  • Provincia: Cagliari (CA)
Inviato 21 August 2005 - 15:05
No no....è una cosa strana...la black box come la intendono loro è una specie di centralina.
Solo che non ho capito se è la centralina d'accensione o chissà cosa perchè ho visto più volte che su qualche sito vendevano la "black box" senza limitazioni e allora a questo punto penso che sia la centralina di accensione. :Baldoria 2:
E' una cosa strana....
#14 AlexMagno
    Onore al grande Wayne Rainey.
  • 1219 Messaggi:
  • Provincia: Avellino (AV)
Inviato 21 August 2005 - 15:15
Io penso che sia come dice aleale, cioè non sa dell'appendice sulla marmitta che va tolta. Io ho la stessa moto del '99 e aveva lo stesso comportamento da depotenziata.
#15 AlexMagno
  • 1219 Messaggi:
Inviato 21 August 2005 - 15:18
Do you have removed the appendix on the exhaust?
#16 ammanna
  • 293 Messaggi:
Inviato 21 August 2005 - 15:27
<{POST_SNAPBACK}>
ragazzi ma l'inglese lo avete imparato al CEPU???
"have you removed the appendix on the exhaust?"
:Baldoria 2: :) :D
Ragazzi questa volta o la va... o la va!!!!!
#17 AlexMagno
  • 1219 Messaggi:
Inviato 21 August 2005 - 15:39
A me sembra che:
1)Lo scopo non sia quello di imparare l'inglese "correggiuto" ma di aiutare na persona che ha chiesto na mano;
2)L'importante è che si capisca il senso della frase;
3)Il verbo "to have" può anche essere usato col "do" nelle interrogative in alcuni casi. Questo è uno di quelli.
4)Si vede che non hai mai sentito gli americani parlà...
#18 CapIReX-65
    Rap Bull Racing Team
  • 12328 Messaggi:
Inviato 21 August 2005 - 15:50
Ma avrà ricarburato? :) Cum al sa dis a in ingleje? :D Cmq dice che monta il 34...Penso di si... :Baldoria 2: ...
Did you have done the right set up on your carburator? How does the spark appear? Black, white or brown? Make this...Do some photo to the engine, the airbox and the exhaust so we can see better that there is something wrong on your baby! :D
Quanti errori ho fatto? :D
#19 ferrocomix
  • 969 Messaggi:
Inviato 21 August 2005 - 17:09
bravissimo per conto mio sei strapromosso.... non avrei saputo avvicinarmi tanto!
#20 fisch88
    DottoreMitomane
  • 2266 Messaggi:
  • Provincia: Belluno (BL)
Inviato 21 August 2005 - 17:44
Io no SPEK inglish.. mi spiace :Baldoria 2:
Aperto anche la domenica!!!
Benza Power 4EVER!!!
