Cagiva Mito 500!
#221
Inviato 26 November 2006 - 14:19
#222
Inviato 26 November 2006 - 14:56
scienziatapazza, il Nov 26 2006, 01:54 PM, ha scritto:
ora che ci penso un attimo però, la marmitta che sputa roba sulla gomma non mi piace molto, è un pò da cambiare....
cmq la marmitta non sarà sicuramente così... deve essere omologata per poterla vendere :wink:
#223
Inviato 26 November 2006 - 17:01
Ceppa, il Nov 23 2006, 07:58 PM, ha scritto:
hai ragione io ho visto il video di cio che hanno detto in cagiva
VENDO DI TUTTO O SCAMBIO,ENTRA A VEDERE!!!!!
supermono in costruzione!!
vendo audio per auto
#224
Inviato 26 November 2006 - 22:44
CapIReX-65, il Nov 26 2006, 02:19 PM, ha scritto:
costerebbe come minimo il doppio...
la moto non la sostituisci con una bici
#225
Inviato 26 November 2006 - 23:23
#226
Inviato 27 November 2006 - 10:04
sciaobellus, il Nov 24 2006, 08:41 PM, ha scritto:
AAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHAAHAHAHHA
miss "anchesesonomagrahoibuchidellacellulitemamelatirocomefossiunastrafiga"
#227
Inviato 27 November 2006 - 13:54
Donnie, il Nov 27 2006, 10:04 AM, ha scritto:
dai 300€ ce li davi anche....
#228
Inviato 27 November 2006 - 16:27
CapIReX-65, il Nov 26 2006, 11:23 PM, ha scritto:
si a tutti quei motociclisti da bar fieri di mostrare agli amici che hanno anche le mutande firmate tamburini
#229
Inviato 27 November 2006 - 17:57
si ma se lo prendeva pure dove dico io
#230
Inviato 27 November 2006 - 21:30
#231
Inviato 27 November 2006 - 23:23
#232
Inviato 28 November 2006 - 23:01
#233
Inviato 28 November 2006 - 23:17
CapIReX-65, il Nov 14 2006, 01:14 PM, ha scritto:
La moto è un monocilindrico da 501cc, 4 tempi, raffreddato a liquido. Distribuzione doppio albero a camme in testa, 4 valvole.
Potenza massima di 60CV, con una coppia max di 50 Nm.
L'impianto frenante prevede un disco anteriore da 320mm e posteriore da 230mm. Le dotazioni ciclistiche sono di prim'ordine, forcella teleidraulica a steli rovesciati da 40mm.
Sospensione posteriore progressiva con monoammortizzatore idraulico. Pneumatici 110/70 ZR17 all'anteriore e 150/60 ZR17 al posteriore. La Mito 500 pesa 133Kg ed ha un serbatoio con una capienza di 14 litri.
Ora non vi resta che toglierle il velo...
Tratto da Motoblog.it
Questa in montagna e in piste lente si mette dietro molte concorrenti di ben maggiore cubatura... :yea:
..non voglio fare ne il guasta feste ne l'antipatico :sad: ..ma questa Mito 500 per quanto carina :italia: (per altro identica al 125cc....COMPLIMENTI.. :fischietto: ) non è proprio nulla di particolare .
E' la moto giusta per creare un po' d'atmosfera intorno all'ambiente Cagiva e basta.
Non voglio sembrare egocentrico e adulatore del proprio mezzo..ma una comune Rs250 (anche se non poi così comune..) questa Mito 500 la svernicia senza ombra di dubbio.. :f4:
Poi nulla da dire..è una bella special..ma si poteva fare meglio..molto meglio.. :wink:
#234
Inviato 28 November 2006 - 23:49
#236
Inviato 29 November 2006 - 00:40
#237
Inviato 29 November 2006 - 00:46
CapIReX-65, il Nov 29 2006, 12:40 AM, ha scritto:
#238
Inviato 29 November 2006 - 06:54
dillo, il Nov 29 2006, 12:46 AM, ha scritto:
sì già nn durano una mazza quei motori, se ci metti anche il turbo devi girare cn il camion d'assistenza cn 2 o 3 motori freschi ogni volta che vai a farti un giro in montagna... :wink:
Occhio che ti sono in scia... rischio di tamponarti!!!!
P.s. Parlatene con chi ha i motard 4T di manutenzione e vedete cosa vi dicono.... forse è peggio della Mito!
#239
Inviato 29 November 2006 - 11:35
..complimenti..questa è veramente una perla di saggezza!!
Ma quante moto in commercio trovi che montino una turbina di serie???..ma per favore.. :dry:
E poi comunque..rimane il fatto che secondo me quella moto rimane ingestibile..
..io dico 60cv non li fa nemmeno a pregarla..e poi, non ne sono certo,eh..ma secondo me con una turbina mica guadagna 40-50cv..quelle potenze le guadagnano le auto su motori ben più grossi..su una moto te ne darà una 20ina a mio parere..
Ohi, poi ognuno è libero di fare ciò che vuole..ma sicuramente mi sento molto + orgoglioso di possiedere un simbolo del mondo motociclistico..di stare quì ad aspettare l'uscita d'1 trattore 4t sinceramente..mah..
..è anche vero che con le restrizioni anti-inquinamento le case costruttrici sono un po' limitate..ma cmq sia...w il 2t! :wink:
....STRA-QUOTO! :wink:
Messaggio modificato da Lancia Delta Evoluzione il 29 November 2006 - 11:43
#240
Inviato 29 November 2006 - 14:39
si te hai capituto tutto... un monocilindrico turbo... e la marmotta? l'hai nascosta tu di la verità...
maxpsx, il Nov 29 2006, 06:54 AM, ha scritto:
max santo subito
CapIReX-65, il Nov 27 2006, 11:23 PM, ha scritto:
dai nn insistere... oramai hai dato 10000000 prove ke sei un motociclista da bar
58 utente(i) stanno leggendo questa discussione
0 utenti, 58 ospiti, 0 utenti anonimi
