Tps Problema
Inviato 20 March 2012 - 14:42
Look at photo thats oli from cylinder.
Inviato 20 March 2012 - 14:45
You must verify that the TPS is working properly, that could be mounted and everything, but you can not turn well.
Inviato 20 March 2012 - 15:13
Inviato 20 March 2012 - 15:32
Tallus, il 20 March 2012 - 15:13, ha scritto:
I meant that you have to see if the component (TPS) runs well
Inviato 21 March 2012 - 15:46
Inviato 22 March 2012 - 14:59
Messaggio modificato da Tallus il 22 March 2012 - 15:01
Inviato 22 March 2012 - 15:48
Tallus, il 22 March 2012 - 14:59, ha scritto:
Verification that the tps sensor is correctly attached to the carburetor cap
Inviato 22 March 2012 - 18:47
Inviato 22 March 2012 - 20:50
Tallus, il 22 March 2012 - 18:47, ha scritto:
use a multimeter (Ohmmeter) and see the value of TPS, also controls how it changes this value by turning the gas
Inviato 23 March 2012 - 10:04
Messaggio modificato da Tallus il 23 March 2012 - 23:16
Inviato 27 March 2012 - 14:08
Inviato 27 March 2012 - 14:16
Ps: How many kilometers can do normal cagiva at 1l of oli??
Inviato 12 April 2012 - 21:52
Maybe someone who have cagiva e3 can check what must be tension in sensor? And connector. Salut
Messaggio modificato da Tallus il 13 April 2012 - 17:21
Inviato 13 April 2012 - 21:45
read page 258
Inviato 14 April 2012 - 13:13
Messaggio modificato da Tallus il 15 April 2012 - 17:53
Inviato 16 April 2012 - 21:01
Inviato 17 April 2012 - 19:37
Inviato 18 April 2012 - 11:23
Tallus, il 17 April 2012 - 19:37, ha scritto:
It should be identical
But before you get one, try to remove the sensor tps from the carburetor cap and turn it by hand, measuring the values again and see if riescia to bring it back to normal.
Messaggio modificato da a7n8x il 18 April 2012 - 11:25
Inviato 18 April 2012 - 13:57
Messaggio modificato da Tallus il 18 April 2012 - 14:04
