Tps Problema
#1 Tallus
  • 133 Messaggi:
Inviato 20 March 2012 - 14:42
I have TPS error becouse my cagiva smoke 1l oli for 300km and my MIL light blinking becouse TPS have error. My cagiva going down at low rpm becouse theres too many oli... Please tell my what I can repair this.
Look at photo thats oli from cylinder.
  • 6888 Messaggi:
Inviato 20 March 2012 - 14:45
You must verify that the TPS is working properly, that could be mounted and everything, but you can not turn well.
#3 Tallus
  • 133 Messaggi:
Inviato 20 March 2012 - 15:13
"Turn well" you mean not giving full power?
#4 a7n8x
  • 6888 Messaggi:
Inviato 20 March 2012 - 15:32
I meant that you have to see if the component (TPS) runs well
#5 Tallus
  • 133 Messaggi:
Inviato 21 March 2012 - 15:46
I check all components and clean all contact and everythink looks okay but problem is still somewhere with tps :/
#6 spina
    PINK MEMBER
  • 7264 Messaggi:
Inviato 22 March 2012 - 02:55
look the light in MIL red led and read the manual to find where is the problem
#7 Tallus
  • 133 Messaggi:
Inviato 22 March 2012 - 14:59
But I know this is TPS becouse there is 1 long light and 2 blink thats means theres tps error. You think that can be shorted wires or problem with some connector? Maybe electro mechanics must see this?
Messaggio modificato da Tallus il 22 March 2012 - 15:01
#8 a7n8x
  • 6888 Messaggi:
Inviato 22 March 2012 - 15:48
Verification that the tps sensor is correctly attached to the carburetor cap
#9 Tallus
  • 133 Messaggi:
Inviato 22 March 2012 - 18:47
I check this many times and looks okay. But what do you think maybe thats some problem with electric if Tps sensor is okay?
#10 a7n8x
  • 6888 Messaggi:
Inviato 22 March 2012 - 20:50
use a multimeter (Ohmmeter) and see the value of TPS, also controls how it changes this value by turning the gas
#11 Tallus
  • 133 Messaggi:
Inviato 23 March 2012 - 10:04
Today I will check this. Ps. How many kilometers can do normal cagiva at 1l of oli?? (sry for eng)
Messaggio modificato da Tallus il 23 March 2012 - 23:16
#12 D.D.Warrior
  • 248 Messaggi:
Inviato 27 March 2012 - 14:08
Did you check the values?
#13 Tallus
  • 133 Messaggi:
Inviato 27 March 2012 - 14:16
My Ohmmeter is broken ,but I must call to my friend and maybe he lend it to me and I check this.
Ps: How many kilometers can do normal cagiva at 1l of oli??
#14 Tallus
  • 133 Messaggi:
Inviato 12 April 2012 - 21:52
Today I check sensor by multimeter and When I set on 20k and check sensor there was 9,50 and on full throttle was ~~5,.... I dont know how to check connector from bike? I dont know what to do this but I try check (on off bike) in all sets and there was no result.
Maybe someone who have cagiva e3 can check what must be tension in sensor? And connector. Salut :)
Messaggio modificato da Tallus il 13 April 2012 - 17:21
#15 a7n8x
  • 6888 Messaggi:
Inviato 13 April 2012 - 21:45
read page 258
#16 Tallus
  • 133 Messaggi:
Inviato 14 April 2012 - 13:13
a7n8x you're best from the best! :Primo: Thats very help me. Now I know my potentiometer is wrong. But now I have one question: Maybe someone have good potentiometer for sell? If 'yes' then I wanna buy it. :)
Messaggio modificato da Tallus il 15 April 2012 - 17:53
#17 Tallus
  • 133 Messaggi:
Inviato 16 April 2012 - 21:01
I see in the aprilia rs 125 2007+ is the same carburator like in my cagiva >> dellorto vhst 28cd but I see in internet there is version 11kw and full power. If I got TPS from carburator 11kw and I replece it to my carb then I will have some block on carb not like the full power?? Or thats only reason when I replecing all carb 11kw for my? (Sorry for english) I know that's stupid question but I must know :D
#18 Tallus
  • 133 Messaggi:
Inviato 17 April 2012 - 19:37
Up. Please reply
#19 a7n8x
  • 6888 Messaggi:
Inviato 18 April 2012 - 11:23
Visualizza MessaggioTallus, il 17 April 2012 - 19:37, ha scritto:
Up. Please reply
It should be identical
But before you get one, try to remove the sensor tps from the carburetor cap and turn it by hand, measuring the values ​​again and see if riescia to bring it back to normal.
Messaggio modificato da a7n8x il 18 April 2012 - 11:25
#20 Tallus
  • 133 Messaggi:
Inviato 18 April 2012 - 13:57
Im trying many times and there was same results on full throttle was 4,5-5 KOhm and on closed was 9,5-10 KOhm. Today I buy one tps from aprilia rs 10' and I tell you what happens when I remove old for new potentiometer :D Thanks for your response.
Messaggio modificato da Tallus il 18 April 2012 - 14:04
